Gelcoat repair - Is it that easy?
I beached the boat once in a sand bar last year. Now I have some scratches on the bottom . I am having a hard time finding some one to fix it now and from what I’ve read, I guess I can do it my self.
My understanding about gelcoat is that it’s a +/- 1/16" layer of resin with color and luster?
I’ve been told to:
Sand 1 ½" around the area in need of gelcoat with no 80,
Apply the gel with a plastic squeegee, let dry
Then sand with 400 , 600……800…….1000…. with a sanding block
Polish with compound the entire area…
Is that it? Will the surface match and shine like it was originally?
I found two places where I can order the perfect color matched white gelcoat for my 2003 Baja.
I’ve been told to:
Neno the mind boggler
Re: Gelcoat repair - Is it that easy?
Originally Posted by Catagory5
No, it's not that easy.
ditto. . . . or PM Gordo and ask him that question
honestly its years of experiance that make it go smoothly (notice i didnt say easy )
08 OPA High Points Champion
Thanks Guys,
Finally hired someone to have it done.
I observed him working so I'l know how to do it next time...
Here is a trick I learned from Him : Spray some primer paint over the scored surface ... You'l know when to stop sanding since the primer will fill the scores in the gel.
yep . . . its called a tracer coat
I have called it "guide coat" and use Dykem (lay out fluid) which is dark blue and applied with a rag and is usually dilluted with acetone. Same principal for sanding out scratches and blocking out low spots. There, now I killed the thread(at least part of it). The legacy lives on!
nothing gets by you G . . .
