Transom rot! Looks like a long winter for me!
Charter Member #232
Re: Transom rot! Looks like a long winter for me!
The wood in the stringer is not what gives the stinger its strenght from what I have been told. It is the glass. The wood gives the glass support. If you cut it up at a angle then you should be fine. This will also get rid of your wet wood. The only way to get rid of the wet wood is to cut it out.
Put your best foot forward!
Well...I got the whole frig'n thing out last night. The other side was alot harder to get out. I would say 12 hours total to cut out the transom. Not counting the mechanicals. My hands look as if they were on a hunting trip with Dick Cheney. Holes everywhere. (real men don't wear gloves...real stupid ones at least). I have decided to cut the stringers, going to do that part this week end. Looking ahead, what materials should I use for this job. Keeping in mind that I will be filling the wholes and gelcoating the exterior of the transom. My old timer buddy tells me to use West sytems boatyard resin and matt cloth. With marine-tex on all the seams. But I'm sure that epoxy is the better choice. Also have been told not to bother with marine grade plywood, by two different and reputable glass shops. I sure ain't looking forward to paying $80 a sheet but I certainly don't want to compromise the job. What do you think? Here are some pics of the transome removed, note how high Formula ran the stringers up the transom.
Originally Posted by offshoreratboy
I made a smoke'n deal on all the Bravo stuff I need for the conversion.
Thanks Guys...
Thanks Guys...
look at the pics of the 311 stringer ....it carries that same height almost all the way forward .....m
Originally Posted by offshore ginger
i guess people in FLA, fix boats like thay build a house . i sure hope it is not because of a hurricane . ha ha ha ha G . G .
come on down ..........
Regular exterior grade plywood is what we always use. We use vinylester unless the boat is kevlar or built with epoxy. Transoms usually only rot because manufacturers send them out of the factory with areas of the wood exposed to water. Just make sure to completely encapsulate your transom with fiberglass BEFORE you use any gel coat. Don't put any wood down in the drain plug area. I usually use a hole saw in this area and cut out a 2" area and after I set the transom i fill it with Adtech and then glass over it. This way even if you don't seal your drain plug assembly water can't get to the wood. Also if you cut away a small portion of the stringer you can use glass to tab the stringer into the new transom and you will be fine. One thing to note is that you do not get GP resin. You don't want to be rushed and GP resins are usually faster curing and also inconsistent. Laminating or vinylester will give you a lot more working time. Epoxy is definitely superior but you have to get mat designed without a polyester binder for use with epoxy. Most boats are built with polyester.
4 ply , that is used for building homes or 7 ply , for marine use
the 3/4 exterior grade plywood they sell at Lowe's is 7 ply with knot free sheathing on both sides (9 ply).
