Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
Prep Work for Painting Engine Compartment >
Old 02-10-2007, 08:58 AM
monstaaa's Avatar
more
Attached Thumbnails Prep Work for Painting Engine Compartment-p1010078.jpg   Prep Work for Painting Engine Compartment-p1010054.jpg   Prep Work for Painting Engine Compartment-p1010056.jpg
monstaaa is offline
Old 02-10-2007, 09:19 AM
Monstaaa, I noticed all of the ones in the pics above were painted before. Will the same steps apply to one that was mostly carpeted? I am getting ready to do mine and have stripped the carpet out. The work looks really good!!
DKerns is offline
Old 02-10-2007, 09:28 AM
Looks Great!!
29scarab is offline
Old 02-10-2007, 09:57 AM
monstaaa's Avatar
most builders use gelcoat in the bilge over the glass work. either way follow the steps above and you ll have no worries. just make sure you start with 80 or 100 on the 8 ". it is important to remove the top layer of gel because of its prosity, which will contaminate and therefore diminish the end results of longevity and appearance of your work.
good luck to all
monstaaa is offline
mcraymond3
04-04-2014 11:55 PM
danh63
Baja
7
02-26-2007 09:33 AM
TeamPSI
7
02-10-2007 07:43 AM
BWebb
2
04-29-2004 10:25 PM
BAD-HABIT
02-25-2002 04:31 PM
Quick Reply: Prep Work for Painting Engine Compartment
