No Gel-coat over epoxy....then what to use?
Thinking ahead to the finish work on my transom project. I'm using the west sytems epoxy. I've been told that polyester over epoxy is a no-no. What can I use in place of the Gelcoat. Is there a vinylester product? This boat lives in the water 4-5 months so I can't use paint.
I have tried everything in the paint family accept awlgrip. Nothing stays on a boat it all eventually blisters below the waterline.
Joe...
Joe...
Charter Member #232
Durratechs product called Durraprime. Make sure that you wash off the Epoxy Anneal (sp?) before you prime. Use a scotch bright pad and soapy water seems to work well.
Jon
Jon
Put your best foot forward!
So if I use the Duratech product as a primer this will be the barrier coat between whatever else I want to use? Can I still use Gelcoat?
Charter Member #232
Yes. If you can find my filling in the windows post you will see how I did it.
Neno the mind boggler
yes it is and you can use gel coat over it. make sure you have complete coverage with the primer. one side note though this product works over "most" epoxies not all. i have had trouble with it on occasion and there really isn't way to tell without buying a gallon and doing a test area. and a Jon said wash off the amine blush with water and dry thoroughly
08 OPA High Points Champion
Charter Member #232
I do know that it works with West system (if I remember that is what you used).
I am also doing some work on the bottom of my 382 with west system epoxy. I called their tech line because I had the same question about gel coat. They said to put two coats of pure epoxy over the epoxy with the faring filler, once fully cured clean off the amine blush with warm water and scotch brite, sand with 80 grit and it is ready for gel coat.
The tech person was very confident that west system epoxy provides a good base for gel, I hope he is right.
Jeff
Jeff
I have been using gel coat over West systems for 15+years,not one failure.Good luck on your project!!
Jeff Glow
Smooth as Glass
(209)869-3545
Jeff Glow
Smooth as Glass
(209)869-3545
Thanks for the info Jeff I really appreciate it. I have been getting lazy with the pics but I will get some tonight for sure...
Joe
Joe
