Pulling my hair out......pros please!
I'm painting a car with Spies-Hecker single stage urethane. The paint turns out pretty good but we are trying to make it very nice.......so my painter friends tell me to D/A with 1500 wet then 3000 wet....then buff.
Well......I do the D/A to 3000.....the paint looks nice and smooth.....then I buff and all you can see is scratches.....they are circular so I'm assuming they are 1500.
We've even started with 2500 a couple days after paint and it looks like hell when we buff......big straight scratches.
The guy doing the body work is a pro with 15 years experience.....the Standox primer surfacer was blocked with 800 before paint......
I know it's hard to help but I need some suggestions....
Thanks,
Aaron
Thanks,
Aaron
Lakeside Restorations.com
Commercial Member
Re: Pulling my hair out......pros please!
Did you use a compound? Also what polish & Compound if any are you using?? I have found that 3m & Presta's stuff works well. Also are you using foam or wool for the polishing (not compounding)..? Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
We painted my 30' Sutphen with Spies- Hecker, I used 3M Buffing & Polishing Compound. After your done buffing ,I used 3M Liquid Ebony. No swirl marks,Just Shine!
It sounds like you are using to agressive of a compound or pad.
3M perfect it compound with a foam pad wors well and follow with 3M Ultafina with the blue foam pad.
Commercial Member
Thanks guys.....we're using foam pads and various 3M compounds but I can't remember what.
I'll check when I get to the shop tomorrow.
Could the mixing ratio have an effect on how hard the paint is?
The data sheet says 3:1 of the hardner we have so that's what we did.
The paint can says 2:1 of some other hardner......?
Thanks again,
Aaron
Thanks again,
Aaron
Commercial Member
It can depending on what you ended up with However if it ended up too hard, you should stil be able to wet sand, compound & polish it out. Depending on how it was mixed it could have also cured to soft. If that was the case your sanding & polishing pads & finish would be gumming up.. Just a thought.. J
Charter Member #232
Make sure that you are using the correct pad with the correct pollish. I had my landloard barrow stuff from us and he came back all pissed that the stuff that he was doing was not as nice as what we did. He had reversed the pads and chemicals.....
Put your best foot forward!
