what is the most durable clear for painting a boat?
Registered User
It is kind of complicated to explain but I hope this helps.
Chris
Geographics
The correct terminology that i was trying to get accross is called bridgeing. The best way to explain it is a seperation or mounding of the product after you tighten a accessory down onto the finish. The last time I used diamont clear it was DC 92, that was along time ago. We liked the product but were not pleased with the color matches. Find croma premier much more user friendly and not as aggressive as the older daimaont. Like I say that was a long time ago, probably 11 years. Someone on oso said that he has had great success with Standox under the water line for extended periods of time. I did my 302 formula 8 years ago with croma premier and like you say it looks like the day you sprayed it. My bottom is original gel coat. We do a lot of boats, and i find it hard to get the gel to come up and stay there.
Yes, all the boats Geo has done have RM clear. I have not had any complaints of such a thing. All my jobs have at least 4 coats of clear by the time I am done the final sanding and polishing. If anything happens such as scrapes or rub marks, they will polish out. One good example is the 40 foot Baja named "Will Power", it was taken very good care of and after 4 years it still looked like it was just painted.
I have used some other products due to product compatability issues and I just like the user friendy aspect of RM.
Thank You,
Chris Diamond
Thank You,
Chris Diamond
Registered User
As per the last two posts, DC 92 does have a tendency to mound if you rush it and put hardware back on too soon after completing. It has been an awesome product for me though. I have no issues blending it for repairs, by the time it is sanded and polished, it looks like a million bucks! I personaly find other clears too "watery", as they seem just not thick enough going on. When you time DC 92 perfectly after drying, it sands and polishes beautifully with the right product and steps.
Again, this is just my personal opinion. Everyone has there own way of doing things.
Thanks,
Chris.
Thanks,
Chris.
Diamont is OK but not my choice. I have had the most success with Standox it is higher in solids content and can be used with a scratch resistant hardner or plasticized to give it more durabilty.
My last boat looked like the day we painted it 3 years later even below the water line.
My 2 pennys.
My 2 pennys.
I wish I knew what it was..an old friend back in san diego worked at north island painting fighter jets..he sprayed some clear on some offroad parts I had, nice shine and damn near indestructable..blasted by rocks at high speed etc... though I think I remember him saying it was majorly toxic spraying it.
if im not mistaken donzi is using ppg now, but to answer the question as far as most durable Imron clear is designed to be just that. for scratches abrasions and the like it is incredibly strong and resistant to the enviroment. it is not so easy to use from a spraying stand point, but it is the strongest clear , medium or high solid.
chroma , ppg, speis , sikkens, h.b body, diamont are all good clears and basicly comes down to user prefernce and the technique they have come accustom to .
