what is the most durable clear for painting a boat?
#31
Flex agent with most paint products simply slows the curing process to allow assembly of plastic parts. The Spies and Standox product it actually becomes a part of the clear and basically makes it more of a polymer. This wont help with blistering but can help with scratch/chip resistance.
#32
R BEYER Did you use single stage or base clear. I see you have posted clear coat numbers. I had the dupont reps drop off a gallon of clear and 2 quarts of hardener. I am going to spray a few test panels. 1 with base and clearcoated. one based clear and flex additive, one base clear reduced 10%. and one over factory finish, no base. Then I am going to hang them in the canal (fresh water) just to see what happens.If standox products hold up under the water line it would sure make my life much more simple. 3 years and still looking great is awsome.
#33
