Auto/ Boat paint into a spray can
Neno the mind boggler
yep but it has to be a basecoat like PPG's DBC or Omni MBC. have them put it in a lacquer can and you will have to clear it. you may have to buy a whole pint for them to put it into the cans. what are you doing with it?
08 OPA High Points Champion
Painting drives, they are not black. they were painted before and have some flaking and rubs on them and need to touch up and dont want to load it on the trailer to take to a paint shop.
I have had my supplier put catylized single stage paint in a spray can but you have to use it within a few hours.
You can get what is called a prevail at the local hardware store and add the paint and use it just like the can and then clean it up and use it again just has a jar on the bottom with the propelant on the top. Can spray gel coat or paint
26sonic
04-10-2003 07:16 PM
