Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
Transom/Stringer Replacement >
Old 10-08-2007, 02:17 PM
  #61
Will only let me use 5 images per post so here is a little background info on the previous posts
Removing the old transom. Almost finished. Notice the line of resin oround the outside of where the old transom was. This is the "gap" that is needed. Grind out the old, in with the new.
Here is the biax I used before installing the transom piece.
And wetted out with epoxy
I used what was left of the centre two stringers, some string, braces and cross members to "recreate" the bottom of the old floor level.
The level is the underside of the 1x4s and the pink string. I then marked the hull with a permanent marker once I was satisfied.
mtnrat is offline
Old 10-08-2007, 02:57 PM
  #62
Laminated stringers with 3/4" coosa bluewater 26.
Measurements from under the pink string and transferring them to stringers
Cut stringers that had to be put in place and trimmed to fit. Much trial and error fitting.
Made some bracing to hold the spacing between the stringers properly.
In place and checked with jig.
mtnrat is offline
Old 10-08-2007, 03:03 PM
  #63
Epoxy and wood flour to glue the stringers down. I also used some silvertip ezfillit but it gets expensive fast, but it did show me the proper consistency to get the mixture to.
Glued down
Smaller second set of stringers.
Glued down in place.
I used a straight edge to get the stringers level, using the marks I had made with the jig that delineated the bottom of the floor. I let the first two cure before installing the second two.
mtnrat is offline
Old 10-08-2007, 07:20 PM
  #64
Awesome Mtnrat. Keep it coming it is very informative. You wouldn't be planning a trip to Oz in the near future by any chance?
jez350 is offline
Old 10-15-2007, 08:14 PM
  #65
tripps's Avatar
Check out my other post tripps
tripps is offline
Old 10-22-2007, 08:41 PM
  #66
tripps's Avatar
All i can say is that i painted the transom,mounted the bracket,the motas are goin on this week and the riggin done correctly by Marine 2000,and the rest is up 2 me!!! tripps
tripps is offline
Audiofn
178
04-03-2015 06:39 PM
VinMan
Velocity
10
05-23-2007 06:40 AM
VinMan
15
05-19-2007 03:49 PM
88 MACH 1
10
10-17-2002 08:56 AM
pb
04-04-2002 09:40 PM
Quick Reply: Transom/Stringer Replacement
