Bilge Paint
Old 11-01-2007, 07:23 AM
MM1 right on!!!
excalibur32 is offline
Old 11-01-2007, 01:55 PM
Lofty's Avatar
Spend your time and money on clean and prep, it will pay in the long run. Any good quality two part epoxy or urethane will work just fine. Make sure to use a two part no matter what anyone tries to tell you, it hold up in the harsh environment of the bilge.
Remember; Clean, rough and dry. Can't emphasize it enough!
If you're going to brush it in start up in the gunnels and work your way down. I've found it is best to do at least a three coats nice and thin. Let it harden between layers. Many thin layers work better than one or two heavy layers.
Attached Thumbnails Bilge Paint-tn_bilge1.jpg   Bilge Paint-tn_bilgewhite1.jpg
Lofty is offline
Old 11-06-2007, 12:25 AM
MM1
I am going to try the IMRON here are some before pics and I will take some more when I finish painting. Matt
MM1 is offline
Old 11-06-2007, 08:45 AM
offthefront's Avatar
Brightside 1-Part Polyurethane Enamel by Intelux ...
offthefront is offline
Old 11-06-2007, 05:04 PM
bouyhunter's Avatar
I wound up going with Bilgekote. Two coats. Probably put one more coat on in the spring before the motor and everything else goes back in.
Pics here
http://www.offshoreonly.com/forums/s...d.php?t=171087
bouyhunter is offline
Old 11-12-2007, 09:52 PM
MM1
After 2 coats of primer and three coats of imron paint it turned out great.
Attached Thumbnails Bilge Paint-founatin-35-009.jpg   Bilge Paint-founatin-35-011.jpg   Bilge Paint-founatin-35-012.jpg
MM1 is offline
Old 11-12-2007, 09:54 PM
MM1
A few more
MM1 is offline
Old 11-13-2007, 05:57 AM
Registered User
Rustoleum Industrial 9100 2-part poly with the water immersion activator is my favorite.
Chris Sunkin is offline
Rebel_Heart
Fiberglass and Paint
13
04-25-2006 12:18 PM
Mikey Likes It
1
03-28-2006 06:39 AM
44MTI
01-23-2005 12:40 PM
carter38
02-17-2004 06:20 PM
boot
02-20-2002 10:32 AM
Quick Reply: Bilge Paint
