DIY Gelcoat Pepair
DIY Gelcoat Pepair
I have a small air bubble void in the gelcoat that broke open. It is about the size of the tip of your small finger. The gelcoat is white and I have a quart from the boat mfg. This defect is located at a compound surface corner of the deck at a hatch recess edge.
I would like to tackle this with a non flowing resin paste that I could color with the original color gelcoat. Is this plausible and what are the products I would need?
If not plausable how should this repair be accomplished?
Neno the mind boggler
give me a call an i'll give you a quick run down on how to do the repair. 419-461-4114
08 OPA High Points Champion
