Any suggestions on building a gauge pod
#41
Great job. I did the same thing 2 years ago when I needed a throttle mount for my little cat project. Carved up some cheap foam I got from HD then just glassed over it, I used epoxy so it didn't eat at the foam. The carbon fiber is in with epoxy as well. Then I just hogged out as much foam as I could then dumped acetone in to clean out the rest.
#43
Thanks Rangerrick63, OSO is full of info this is my first glass job and if not for the help from the pro's here I wouldn't have attempted it. I got the aluminum panels cut out today and did some bondo and sanding need a little more and it will be ready for paint, I sent all the gauges I bought on e-bay to Livorsi and had the rims changed to polished stainless and have them all tested before the install. I will be using the mustard bezels to accent the stainless rims. By the way I had a 28zx and loved it, it had a blown 502 and 700 hp. More pic later. VV
![](http://i265.photobucket.com/albums/ii230/velocity320/DSC_0006-2.jpg)
![](http://i265.photobucket.com/albums/ii230/velocity320/DSC_0005-2.jpg)
![](http://i265.photobucket.com/albums/ii230/velocity320/DSC_0004-3.jpg)
Thanks Paul
#44
#46
Crazy Energy
1 Post
Finally found the time to finish my gauge pod and Livorsi Monster gauge swap, I also changed the switches to black to match the black gauges. Now all that is left is the install back in the Velocity 320.
Before
![](http://i265.photobucket.com/albums/ii230/velocity320/1038_1.jpg)
After
Before
After
![](http://i265.photobucket.com/albums/ii230/velocity320/DSC_0002-1.jpg)
#48
Crazy Energy
1 Post
Houston, we have contact! I would like to thank everyone for their input and help during the Monster swap. Some pictures of the finished project.
Before
after
![](http://i265.photobucket.com/albums/ii230/velocity320/DSC_0006-6.jpg)
![](http://i265.photobucket.com/albums/ii230/velocity320/DSC_0004-7.jpg)
![](http://i265.photobucket.com/albums/ii230/velocity320/DSC_0005-8.jpg)
Before
after
![](http://i265.photobucket.com/albums/ii230/velocity320/DSC_0007-3.jpg)
