Gel Coat or Awlgrip
Ditto on all'a dat
But if you absolutly hafta paint use Awlgrip.
mcprodesign- Its been years since i used Awlgrip (late 80's) what does heating it do? will it still work if you dont or is that a technique to help it flow? does it actually say on the tech sheet "dry popcorn fart lite coat"
. . . . . welcome to OSO by the way. I'm just glad somebodys here that has been painting longer than i have (87)
Gel on the bottom always. Donzi's in house graphics are second to none in quality, i havent used Diamont yet (i'm a PPG guy for the most part) Gonna hafta give it a try
![Cool Smiley 011](/forums/images/smilies/cool-smiley-011.gif)
![Wink](/forums/images/smilies/wink.gif)
Neno the mind boggler
cool, its been a while for me and i like to keep up on that stuff. I have an extremely large project that i am helping a friend with (several hundred feet) and Awlgrip is the top contender at this point. Its nothing i will be spraying my self, this is an automated system. Thanks
08 OPA High Points Champion
Lakeside Restorations.com
![](https://www.offshoreonly.com/forums/images/icons/commercial_member_star.gif)
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
you can in fact brush or roll awl grip. and then wet sand with fine grit in steps say from 600 to 100 to 1500 and then buff to an incredible shine. this method for very large areas such as bottoms also saves on material. especially when the user is not accustomed to using this product as it does has its difficulties.
bottom line is it is not porous as gelcoat is. has a more impregnable chemical structure than gel and when applied v.i.a roller or brush can be done so where it will even remove slight imperfections and work almost as a fairing compound.
Thanks for the info. I see its an Axzo Nobel product. That is "Sikkens" then. I know a dealer in Welland and will have to ask him to get me some of this product.
Thanks again for the info.
No, it is not necessary.
