how to fill dash holes
Charter Member #232
Did you taper out the edges MF both front and back of the hole? If so you should be fine.
Put your best foot forward!
Neno the mind boggler
pretty similar. i use a course round rasp to prep the hole. you cant just fill in the screw hole as there are usually some fine stress cracks around it from when it was first driven in. Are you painting over or gelcoat?
08 OPA High Points Champion
painting it, heres my new dash, this 21 shadow had a goofy z shape, I decided to use the smartcraft screen so I cut it out as well as made a side console to house switches etc, also put a new transom in to support 18 inches of set back and cut out the splashwell and built a new rear section with hatch
