Single stage metallic, or two stage?
Had a little accident with tailgate and need to replace it and paint it. Currently have the reducer and hardener for single stage, but I am having second thoughts about using it with a metallic paint. (Dark Gray Metallic). I keep the truck clean, but not waxed, so I am not looking for show car finish. Just looking for some feedback on the single stage metallic aspect. I know the wet sanding polishing of the single stage is a going to show, but was thinking about mixing in some compatible clear with the top coat.
Jim
Jim
Lakeside Restorations.com
![](https://www.offshoreonly.com/forums/images/icons/commercial_member_star.gif)
If shooting an entire panel thats one thing. If you are going to blend it is more likely to not blend or look blemished in my opinon as well.. Base clear I think would be the better way to go... Jamie
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
bc/cc. the metal flake in the singlestage likes to group and look blotchy, due to static electricity. unless you are a pro don't do it believe me I learned a very expensive lesson!
