Vibra Cut
Wow Dave...that looks good. Now I'm definitely going to have to try some as soon as I get a chance. I really like my Aqua Buff, but you're makin a believer out of me.
Dave, if I just want to maintain my shine on my boat can I just use Vitreo and an orbital or will I need to use a polisher? I am afraid since I am new to a polisher that I could ruin my gel coat.
Dave, a question for you: My boat's gel is getting a bit thin in several spots, so I am pretty hesitant to hit it real hard with anything aggressive. It is kept indoors most of the time, but the light/dark blues in the gel still dull down over time. I usually just hit it with some of the 3M swirl remover (grey) and a foam pad, and follow up with some good Carnuba wax, but this stuff looks impressive from the pictures.
Is the Cut and Buff going to be too aggressive for my old gel coat? Would just using the Vitreo produce good results on a gel that is kept up and does not have a lot of exposure?
Thanks!
Thanks!
Neno the mind boggler
Bud they have a lighter product called Quick Step that may be what you need. Totally Buff can also be used with a lighter touch though, the product breaks down as you work it and sort of turns to a light polish and self cleans towards the end of it's duty cycle. Either way I would use Vitreo for the final surface
08 OPA High Points Champion
