Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
How hard is Fiberglass for the DIY?? >
Old 10-09-2011, 08:35 PM
I live close enough to Michigan Fiberglass Sales...http://www.michiganfiberglass.com/products.html... Do they sell quality products, if you are familiar with them?
coolmedown is offline
Old 10-09-2011, 09:18 PM
Neno the mind boggler
glassdave's Avatar
yeouch those guys are way expensive. i use these guys for a lot of stuff and there pricing on small quantities is really good, even with shipping its cheaper than Michigan fg.
http://uscomposites.com/polyesters.html
435 is a good standard layup resin for what your doing, anything structural and the upgrade to 700 vinyl is a good choice.
08 OPA High Points Champion
glassdave is offline
Old 10-10-2011, 12:49 PM
I have used UScomposites for a long time also, can't rememeber when I started using them (used to order from paper catalog!). They have always been fine to work with, never dissapointed.
Fibreglast.com also. More expensive typically, but they do carry top notch supplies and a bunch of info available online.
Brian
befu is offline
Old 10-10-2011, 04:42 PM
Is the 2oz chopped strand mat from US Composites the same as 1808 Biaxial? If not who has the cheapest prices on the 1808?
Old 10-10-2011, 04:57 PM
Never mind my above post. i found the Biaxial on their site.
Old 10-10-2011, 05:02 PM
So if I was going to do a 4 foot by 2 foot area how much resin should I buy...Im guessing 1 gallon but is 2 needed?
Old 10-10-2011, 05:19 PM
Would you cut one piece 4 foot by 2 foot or make strips say for example 6 inch by 12 inch?
Old 10-10-2011, 06:05 PM
glassdave's Avatar
assuming the dash is cored with ply i would cut a piece of wood that fit snug and bond the edge all the way around with the 404 and let it cure. Then go back with a die grinder and scarf the face down level with the core. This way you have a nice stable surface to lay the laminate on. Do it in full sheets, you should only need two or three layers cut consecutively larger (or smaller) so the thickness of the layup follows the scarf. This will minimize the grinding needed after it cured and will be easier to level out.
Old 10-10-2011, 06:12 PM
Thanks Dave. If you could aid me with quantities that would be much appreciated.
Old 10-10-2011, 06:30 PM
And im thinking 3" brushes. True or not so true?
