Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
Modifying strakes on a 24x7 hull (24 Pantera)? >
Old 08-06-2012, 11:48 AM
  #51
onesickpantera's Avatar
Originally Posted by tomas_wallin
Thanks!
No, only with the old 454 and TRS...
There's quite a difference!
So you did drive it with the 454/TRS package before modifying the strakes and pad?
I was just curious on what the strake/pad mods did for ride attitude. Does the boat ride flatter at high speeds? Etc.
onesickpantera is offline
Old 08-06-2012, 11:53 AM
  #52
tomas_wallin's Avatar
Yes I did for a couple seasons. It was nothing like what it is today, can't even compare.
I will get someone to take photos of the attitide etc on the next test! I will also try some 3bl (Tempest and Mirage Plus) props to see what happends.
tomas_wallin is offline
Old 08-08-2012, 02:46 PM
  #53
Pics would be great! Videos would be even better.
Old 08-08-2012, 05:30 PM
  #54
Tomas,
If you test lengthening the inner strakes, we ended up at the best length being 6" past the CG. We just just screwed and glued on wood for testing.
Ben
BenPerfected is offline
Old 08-08-2012, 08:38 PM
  #55
Originally Posted by KMP
Looks great. I also have a P&D, which (so far) only blueprinted the bottom taking out the hook as recommended by Joe N., (Pantera did not put the hook but P&D did). I am running a 540 NA engine with IMCO extension box and easlily hit 84 with 28 Bravo; rund smooth and controllable.
I did a strake extension on my 18 Donzi Classic and like the way it runs. I do not use tabs anymore and it sits on top of the chop a lot flatter at speed. Begreat to see how your project runs because I had considered extending the inside strakes on the P&D.
Kent
From what I was told, the Pantera and 24 excalibur are the same hull? Is this true and if so does it have a hook? I just bought a 24 Excalibur an am replacing the transom now and plan to blue print the bottom next. Any help would be appreciated
Attached Thumbnails Modifying strakes on a 24x7 hull (24 Pantera)?-24-excalibur1.jpg
78tahiti is offline
Old 08-08-2012, 11:39 PM
  #56
Originally Posted by BenPerfected
Tomas,
Ben
Where was that measured from the transom? I lenghtened mine about 2-1/2ft.
Old 08-11-2012, 02:57 PM
  #57
No videos but at least some pics...
Old 08-11-2012, 03:13 PM
  #58
Lee
Lee's Avatar
I noticed the "MC" registration numbers in previous pictures, was this boat originally
named "Trick or Treat"?
Lee is offline
Old 08-11-2012, 03:19 PM
  #59
Yes, that's correct
Why are you asking?
Old 08-11-2012, 04:10 PM
  #60
Lee
Lee's Avatar
Friend of a friend was a previous owner in the 1990's here in Michigan. Båten ser utmärkt.
Lee is offline
