Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
What Color to Paint Bilge >
Old 07-07-2013, 06:23 AM
Craney's Avatar
Default What Color to Paint Bilge
The engines are coming out for bigger hp,I'm going to paint the bilge but not sure what color to paint it. The boat is bright blue with a white strip,the bilge now is gray. Should I paint it blue or white???
Craney is offline
Old 07-07-2013, 07:12 AM
How about blue and white.......or all the colors of the boat
Attached Thumbnails What Color to Paint Bilge-ernies-boat-001.jpg   What Color to Paint Bilge-img_0154.jpg
brian41 is offline
Old 07-07-2013, 07:58 AM
if your installing strokers and the blocks DO NOT have one piece rear main seal, correct windage or breathers, paint bilge black so you wont see oil drips
KEVLARKAT32 is offline
Old 07-07-2013, 09:26 AM
White. Splatter paint went away with the cassette player and personally I would want to see any leaks/drips. Use a quality 2 part system so it doesn't stain.
POWERPLAY J is offline
Old 07-07-2013, 09:40 AM
Jay, When did they do away with cassettes?....Just added a cassette player to my boat. Looks better when you add these.
Attached Thumbnails What Color to Paint Bilge-dsc01512.jpg   What Color to Paint Bilge-ernies-boat-021.jpg
brian41 is offline
Old 07-07-2013, 09:58 AM
vintage chromoly's Avatar
I agree 100%. I want to know if I'm leaking anything and splatter is outdated in my opinion.
White is clean and you will know if anything is suspect.
vintage chromoly is offline
Old 07-07-2013, 10:00 AM
What the hell are cassettes?? I must have missed something when I was busy rewinding my aerosmith tape that the 8 track ate. You know, scotch tape is pretty good for splices to get all the twists out.
phragle is offline
Old 07-07-2013, 10:41 AM
Sorry Brian. I couldn't resist. Let me know when I can pick up the ones in the bottom pic and I will let you splatter my bilge.
Old 07-07-2013, 11:48 AM
onesickpantera's Avatar
Originally Posted by vintage chromoly
white is clean and you will know if anything is suspect.
x2
onesickpantera is offline
Old 07-07-2013, 11:52 AM
Craney's Avatar
Yes they are strokers and the blocks 2 piece rear main seal.
Craney is offline
