vinylester stringer & transom ?'s
Fixx,
The approach to insulation on a larger scale by using the coffee cup analogy seems so simple yet the simple things fly right over my head......When I heated my portable
shelter I never gave thought to the speed of heat loss, but my pockets did as well as the many propane cylinder refills .........the video was cool!!
seabold236,
I would not undertake a massive overhaul with the boat on a roller trailer. you might loose strutural integraty with the whole interior framework missing
But, Dave would answer this better though............I've used Vinylester a year after expiration with no bad effects....as long as you keep at a consistant
temp below 60 or refrigerate but not freeze it it will last.........I kept mine in a unheated garage through the winter. All resins will eventually kick sooner
or later, but you can slow it down with lower temps and also shake it up aleast twice a week.
The manufacture where I buy my vinylester resin from stores it in big vats......I aked him, what if you don't sell all of it before a period of time goes by?
he answered by saying, the resin is always kept moving so it doesn't start to thicken by air hoses at the bottom by keeping it bubbling...partial answer.
seabold236,
yeah I didn't think it would be smart to cut everything out just wanted a second opinion. I'm glad to hear the resin will last until spring. Should I leave it sealed in the pail until it gets warm out? Or is it OK to use some for the smaller things that I can do in my garage?
My garage is about 60* I used a heat lamp on a small project (laminated 3 pieces 3/4" ply for transom) to remove any doubt that the resin would kick right.
so you can fiberglass as long as the temps are constant and are above 60*........Always try to minimize the air space when storing resin.......I bought a 5 gal.
pail of vinylester resin used up 4 gals. quickly, but didn't leave the remainder in the pail I put it in a 1 gal. jug just to keep as much air out as possible.
Rite now I have the stringers and bulkhead out and the hull ground clean, is it smart to remove the transom at this point? If its safe to remove it would give me a good jump on rebuilding in the spring when it gets warm.
photobucket.com/user/seebold236/media/IMG_20131009_205936_506_zpsf2ff032c.jpg.html
Thanks for all the help and info, its a huge help
Your link wasn't working. Here is the picture:
http://i1272.photobucket.com/albums/...psf2ff032c.jpg
