Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
Clear coat over gel >
Clear coat over gel
Clear coat over gel
Old 10-03-2014, 04:54 PM
augie58's Avatar
Default Clear coat over gel
Has anyone sprayed clear coat of over the exterior gel. Thinking of doing this as a winter project to increase the gloss.
augie58 is offline
Old 10-03-2014, 08:49 PM
it works but the uv resistance of the clear is not as good as spraying a base coat first a lot of boat builders did that and the clear started pealing after 6-8 years if left out in the sun too much,if the gel is in bad shape you will probably get some fish eyes also
MDGperformance is offline
Old 10-03-2014, 09:53 PM
I just finished removing the horrific looking clearcoat the po put on mine. It was scaleing and pealing everywhere.
Btw easiest way i found to remove the clearcoat was to use packing tape. Removed clear and did not leave sticky residue.
Good luck
GLENAMY 242SS is offline
Old 10-07-2014, 04:23 PM
I got through Grad school doing it to bring back metalflake boats shine! I used Aircraft Imron back then. I would shoot a couple of rounds, wet sand, and shoot a final. I was there 4 years and never had a comeback! Gelcoat is great primer, but you have to make sure ALL the old wax that is sitting in the pores is removed and there are is a good "tooth" cut into it for the clear to adhere to (absolutely no shiny spots). Dupont (back then) didn't even recommend you wax Imron for 3 years. I'm not sure what product you could use now, so many companies have such new stuff. I go into the Auto Paint stores and just ask what's best for this or that project.
CDShack is offline
