Gelcoat damage, how should I fix this?
Neno the mind boggler
looks like a small air void or bubble that finally let go. You'll have to open it up a bit to get to some good glass, because its on an edge maybe a piece of 80 grit wrapped around a half or three quarter inch dowel and just run it over the edge to leave a semi round transition. Traditionally 36 is best for a bond but because its on a sensitive edge you want to go a bit finer to keep it from fragmenting further. As said above the gel kits from West Marine work good for this kinda thing
08 OPA High Points Champion
I had a couple of these right on the edge of the chine like yours on my boat. A gel paste kit from Spectrum worked perfectly. Been about 6 or more years now and repair is still invisible. Like Dave said, i took some 80 grit and knocked backed the edges a bit before filling.
