Transom replacement on Checkmate 281
#93
I didn't see pics of engine mounts done yet, but there's pics here of what I did in my last boat using aluminum angle. Will probably be doing this one as well.
Convincor GTX by Scott Baska Photobucket
Also I like how your doing the bulkhead. Much better than the laminate they used..
#94
![Lolhit](/forums/images/smilies/more/lolhit.gif)
Your motor mounts look good I will probably do something similar.
#95
Are you spaying the dykem guide coat after you thin with acetone or wiping it on? Nice thread.
Regards
Regards
Browning Restorations - Wood and Vinyl Bulkhead Installation and Repair
#98
![Transom replacement on Checkmate 281-img_7076.jpg](https://www.offshoreonly.com/forums/attachments/fiberglass-paint/575048d1518112865t-transom-replacement-checkmate-281-img_7076.jpg)
![Transom replacement on Checkmate 281-img_7075.jpg](https://www.offshoreonly.com/forums/attachments/fiberglass-paint/575042d1518112374t-transom-replacement-checkmate-281-img_7075.jpg)
Not nearly as smooth as I wanted....
![Transom replacement on Checkmate 281-img_7077.jpg](https://www.offshoreonly.com/forums/attachments/fiberglass-paint/575043d1518112374t-transom-replacement-checkmate-281-img_7077.jpg)
![Transom replacement on Checkmate 281-img_7083.jpg](https://www.offshoreonly.com/forums/attachments/fiberglass-paint/575044d1518112374t-transom-replacement-checkmate-281-img_7083.jpg)
![Transom replacement on Checkmate 281-img_7078.jpg](https://www.offshoreonly.com/forums/attachments/fiberglass-paint/575045d1518112374t-transom-replacement-checkmate-281-img_7078.jpg)
#100
it looks awesome, your doing some great work !
if you find a way to shoot gel so that wet sanding is minimal to non existent, please tell me
what type of gun, tip size and psi are you shooting at ?
what product are you using so the gel dries ?
2 coats ? activated gel, then activated gel w/ whatever product for the air dry
there is touch up on my boat that hasn't happened yet only because wet sanding is outside of my ability
i can go from 800 to 2000 changing directions each grit w/ clean water every time, buff it and still see sanding marks
when the sun goes across it.
