Can't get a gloss on gel - Help
Out of curiosity, what did you start sanding with? I had a Formula that looked like yours, and I started with 400, worked up to 1000 and then buffed with 3m super duty. Turned out great.
onesickpantera (11-18-2020)
I'm not sure if your read this thread or not but Dave breaks down how he does it with FOY really clearly. If that doesn't work then I would say you are SOL
Fountain Of Youth compounds
https://www.fgci.com/item/123861/Buf...1000-W-Gallon/
A Makita variable speed polisher and a wool pad. Best results I have had to bring up polyester .
That might be my problem, I'm probably not building up enough heat. Don't want to, or know if I can burn gel like paint. I might give it another shot with Presta and build some heat.
I’ll ad the 3M 06044 has done a fantastic job on mine. Took it from 600 grit wetsand to mirror polish. Use only 3M wool pads an a DA style machine. Put it on wet and gently decrease pressure until it’s gone. Then I throw a coat of wax on. Best product I’ve used.
Neno the mind boggler
![Cool](/forums/images/smilies/cool.gif)
Vibra Cut
08 OPA High Points Champion
This summer I was finally able to get a gloss on my boat... Lol
Click below.
Extreme Measures... Make Over Edition
Click below.
hoodoo (10-12-2020)
If you started with 600 and did not spend enough time with 800, 1000, 1200, 1500 before that 2000, you may have scratches that are keeping it hazy.
I believe I spent enough time with the each grit. I was only working a small area a square foot or so. I spent hours on just one area. Also with all kinds of products not only sanding.
