Completed "Thru-thunder" swim platform modification
for those that wanted to know what it sounds like.
check out my video i jsut finished. it will tell you.
so, TURN IT UP !!!!
after going to this link, right click under the icon and choose "open in new window"
Rambunctious Video
so, TURN IT UP !!!!
Rambunctious Video
Toxic FORMULA
Way cool video man
If you want another project , check out these Johnson crank mounted sea water pumps on my 272 with 540s.
The impeller is a 15 minute job and that includes searching for the spare that you put away somewhere![Big Grin](/forums/images/smilies/biggrin.gif)
Plus the fact I now have two less belts to worry about too
![Cool](/forums/images/smilies/cool.gif)
![Smilie](/forums/images/smilies/smile.gif)
Very nice that should keep some of the winter blues away, the boat sounded great.
Now if we could get Mopower to do a small video with those 540`s
Now if we could get Mopower to do a small video with those 540`s![Big Grin](/forums/images/smilies/biggrin.gif)
Toxic FORMULA
Now if we could get Mopower to do a small video with those 540`s ![Big Grin](/forums/images/smilies/biggrin.gif)
And I'll tell you what...with those 540s ya gotta sit down , shut up , and hold on
![Wink](/forums/images/smilies/wink.gif)
Well I saw Rambunctious video and I knew my platform was coming off. Well it was such a nice day and only a few bolts away, why not go for it. Not a bad job for two people.
My next question is what size plywood did you use marine of course 1/2 inch? I was searching around for some ideas for the exhaust and I found that Dana marine had flexabile exhaust hose $1.75 PER INCH
. I think I can have a stainless piece made for the exhaust outlet.
what do you think?
![EEK!](/forums/images/smilies/eek.gif)
what do you think?
I think it was 3/4" marine. not sure. I would not skimp on the wood thickness if you go through the trouble of rebuilding , since the plywood is the failing part. Look at my pic again to estimate the thickness... but seems like 3/4". I had the work done by my local marine guy so i did not spec the material thickness myself.....
It is strong now !!!
Ramb
Ramb
Originally Posted by MadMat
Me too! Except my platform's staying off.
I blame Formula Outlaw
I resemble that remark....
![Drink](/forums/images/smilies/drink.gif)
LOOKS #@(*#!G GREAT.......
