Docking lamp replacement ... >
Old 07-07-2005, 08:39 AM
offthefront's Avatar
Default Docking lamp replacement ...
Bulb out ..... do you pull the outside off or from the inside .. I use em alot looking for the "save the manatee" signs ....
offthefront is offline
Old 07-07-2005, 09:21 AM
Poorsche's Avatar
Default Re: Docking lamp replacement ...
On my '86 Formula there is a set screw--(allen) on outside and bulb is really a headlamp bulb.
Poorsche is offline
Old 07-07-2005, 09:23 AM
Were doomed!
Wally's Avatar
Hard to say without knowing what type of light it is.......the ones i had on my Scarab i had to get at them from the back...inside the boat. It was a pain to do but i didnt want to break the seal around the hull and have a leak. And the fact that the bolts holding it in place had nylock nuts on the back didnt make it too easy as a one man job!
-Wally
Wally is offline
Old 07-07-2005, 03:04 PM
wantsa311's Avatar
There was an extensive thread on this topic a couple months ago. Search for "bulb replacement"; it was started 4/30 by dawiz74. BTW - Do you really cruise with them on? I was told it was illegal.
wantsa311 is offline
Old 07-07-2005, 05:15 PM
Toxic FORMULA
mopower's Avatar
My '89 are gotten to from the inside. The bulb comes out with the white ball around it. You can buy the complete unit or it is possible to take the ball apart and replace just the bulb but it really wasn't designed that way.
Yes I do run with mine on occasionally in one particular snakey spot with reflective and NOT illuminated markers.
mopower is offline
Old 07-07-2005, 06:29 PM
Dont cruise ....but flash em on every now and then ...I know about where most Makers are but still have to look for em at night ....same as a hand held ...
Old 07-07-2005, 06:31 PM
thanks cal .... I would assume ours are the same,.
Old 07-08-2005, 06:55 AM
Toxic FORMULA
mopower's Avatar
Mike ,
A picture's worth a thousand words
They're Morse lights and also adjustable from inside
mopower is offline
Old 07-08-2005, 09:29 AM
thats them .....thanks ... now to find some aircraft landing lamps....
Old 07-08-2005, 09:53 PM
Formula Outlaw's Avatar
You could get a red and green lens and REALLY have a "bow" light..
Sheesh, with all "those ways" to send a messeage to "offthefront", hell I didn't realize you were that important.....
Formula Outlaw is offline
Quick Reply: Docking lamp replacement ...
