Bravo Transom Plate Pic w/ Stellings
Here's a pic of taken the transom plate through the access hole on the side of the stellings extension box. As you can see, I could raise the boxes up 2 holes (2") but the transom plate which remains stationary will interfere with the drive shaft as it move up. I'm thinking an air powered reciprocating saw will cut the top half of the drive shaft hoop right off the plate and then I can raise the boxes.
You know it's getting serious when you start cuttin'.![Smilie](/forums/images/smilies/smile.gif)
Notice the small cable zip tied to the drive lube monitor hose. That's my new ground strap. I'd taken more pics of it, but ground straps are a little on the boring side.![Smilie](/forums/images/smilies/smile.gif)
Garrett
Garrett
What's with all the rust?
![Frown](/forums/images/smilies/frown.gif)
Garrett
1 Post
Garrett,
Grabbed some pics for you today for comparison. Box is set 3" above the radius where bottom notch and transom blend. Mine are set to middle hole:
Originally Posted by RedDog382
Garrett,
Have you ever tried raising your drives to the highest setting?
I've been kicking around the idea of buying some IMCO shorty lowers or some BMAX Crescent lowers that are 2" shorter, and then raising the box 1" at a time if the result with the shorty's is good. Do you know anyone that has tried this?
The other thing I could do is just raise the boxes two notches and see what happens.
I do have an air powered reciprocating saw on order to modify the transom plates.
Thanks again for the pics!
Garrett
Charter Member #232
Norts set up is a very good one. Boat is SUPER stable and does not do any funny stuff, well as long as you keep the tabs up and the drives up in a fallowing see RIGHT NORT!!!!
I think Pam is still drying off from that run LOL Ummmm we are on Dock 34 ok how about 56? 132? Guess it is hard to zoom a car race while in a boat!!!!
Jon
![Drink](/forums/images/smilies/drink.gif)
Jon
Put your best foot forward!
1 Post
Garrett
Garrett
Glad to help you with the pics.
I have not tried raising my drive height. I think Formula has experimented a lot and acheived the optimal X-dimension on the 382. I'm afraid planing would become very difficult (these are heavy battlewagons to get moving) and I run in some high pitched irregular wave patterns on Lake Erie and Lake St. Clair. I think it would be hard to keep the props hooked up if raised any higher.
You might want to consider some kind of coating on the transom plates after you cut them. Once you break the powdercoat barrier, they will begin to corrode quickly in the exposed areas.
Chris
