fuel sender is leaking.... >
Old 06-20-2006, 07:37 PM
chuck21401's Avatar
Default Re: fuel sender is leaking....
One other thought...are those metric threads? Are the threads on either the tank or the bolts stripped?
chuck21401 is offline
Old 06-20-2006, 07:45 PM
NO WAKE ENFORCER
88formula223's Avatar
yeah Im pretty sure they are metric (Germany) I did replace one with a larger bolt type machined screw, I think Im going to try that with the one that is leaking.
88formula223 is offline
Old 06-21-2006, 06:37 AM
Charter Member #232
Audiofn's Avatar
Yup check for any surface imperfections on the tank and check all the threads on the tank and bolts. Then what I do is use lock tight on the bolts. DO NOT use the red stuff. I think it is green that is the lowest holding strength, blue is probably ok as well. This will not only help to seal up the threads a little but also keep the galvanic corrosion from happening btwn your bolts and tank. Hope that helps
Jon
Put your best foot forward!
Audiofn is offline
Old 06-21-2006, 08:51 AM
NO WAKE ENFORCER
thats a good idea Jon thanks
razor1115
Fountain
11
04-03-2008 09:04 AM
edge_kw
08-08-2007 07:01 PM
Steve A.K.A RAMPAGE
4
05-02-2005 01:06 PM
JGB
22
09-24-2004 01:44 PM
JGB
Cigarette
0
09-24-2004 09:21 AM
Quick Reply: fuel sender is leaking....
