kaama oil pans ?
Charter Member#568
kaama oil pans ?
I've got a 357 with kaama drives. I'm putting new 540s in and need new pans. I was told the clearance is pretty tight because the engines are mounted lower. What pans can I use other than the stock 8 qt. truck pans ? Engine builder said he would like to use one with a kickout if it fits.
Straight bottoms and flat decks
Re: kaama oil pans ?
I think the Kaamas actually sit hgiher. If you look at my transome closely, you can see where the stock exhaust holes are lower than the Kaama exhaust.
