292 fastech 3 vs. 311 or 312 >
Old 10-03-2006, 06:14 AM
birdog's Avatar
Default Re: 292 fastech 3 vs. 311 or 312
Bob...Maybe you mean the "311"...My buds 312 Fastech runs upper 70s {GPS} with 454 mags...A 311 is a HUGE boat and very heavy. Wave crushing tanks for sure.
birdog is offline
Old 10-03-2006, 07:22 AM
cuda's Avatar
Personally, out of those choices, I'd pick the 311. It will be older, but you will have more choices in your price range. You won't find many newer ones of any size in that price range, unless they are hurricane survivor boats.
Sure you don't want a 302? I just downsized from a 302 Formula to a 22 Donzi.
I was kind of wishing I had taken the 302 to the Donzi Hometown Rally last weekend when we hit Tampa Bay.
Attached Thumbnails 292 fastech 3 vs. 311 or 312-a1a-small-.jpg   292 fastech 3 vs. 311 or 312-img_0181.jpg   292 fastech 3 vs. 311 or 312-img_0193-small-.jpg
cuda is offline
Old 10-03-2006, 07:47 AM
21 and 42 footers
t500hps's Avatar
No way the boat ran those GPS speeds without some "extra" work somewhere. I just sold a 312 with 502's. Although it needed a few nicks fixed on the bottom and could have had the props tuned for a little more bow lift 73 was the best I ever saw on GPS. (70 on those 98 degree summer days) Mind you I was running 30HP more per side. I still say scrap the 292 option......a 311 (or even Cuda's 302 ) would be the best bet.
t500hps is offline
Old 10-03-2006, 10:31 AM
Here's the spec sheet on the 312 from Formula. Its a little hard to read - I copied it from another old posting. If you open it up full screen, you can read it ok.
bob_t is offline
Old 10-03-2006, 10:44 AM
21 and 42 footers
t500hps's Avatar
T 454/385......69-72 MPH
T 502/415......71-74 MPH
and BTW: Others will insure these boats, I have had State Farm for both the 312 and the 382. (boats must have stock power and not exceed 75 MPH)
t500hps is offline
Old 10-03-2006, 01:46 PM
birdog's Avatar
He runs every weekend out of Catawba island on erie...
He and i have run together more times than i can count & my Bullet could walk him around 78-80...His does have a diff gear than a 1.50 and some fancy looking air cleaners { }
Other than that and lotsa $ labbing props he is bone stock
birdog is offline
Old 10-03-2006, 02:35 PM
When I was looking, I talked to my state farm guy and he contacted their underwriter about a 312. They would only take it if it had the 330s'. Said they didn't want anything faster than mid 60s, which is an improvement from where they used to be! Must be the difference in which underwriter happens to answer their call.
bob_t is offline
Old 10-03-2006, 02:56 PM
birdog's Avatar
Your agent is EVERYTHING with State Farm...He and I have the same agent..
If you move back here...I'll fix you up...
birdog is offline
Old 10-03-2006, 03:02 PM
21 and 42 footers
t500hps's Avatar
he's running 1.65 bravos (they all came that way) and 30 pitch 4 blade bravos.
If he has changed air cleaner, exhaust, labbed props, changed gears, or some other "extras" then it's possible....but like I said,it's not "stock" anymore......maybe he just has one that somehow the bottom is wrong but works just right, good for him!!!
t500hps is offline
Old 10-03-2006, 04:20 PM
birdog's Avatar
Yep...1.65..didnt know they all came that way....all stock except air cleaner
It didnt change a thing. I helped put them on. His "speed" props are 30s
"one hit wonders"is what Cavanaugh called them..
Like you said...He just got a strong one but....it is a long way from.."lucky to get 70 with 502s" that started this conversation. That sounded like a 311..
birdog is offline
Quick Reply: 292 fastech 3 vs. 311 or 312
