Silent Thunder removal on newer FasTechs
#41
I know now why to remove the ST.
Da*n the vibration noise it makes. On the rare occasion that it stops for a second, you can hear the sweet sound of the engines. And then it starts again... Grr..
I'm on the market for a set of clamp-ons right now. Let me know if you see a good deal my way.
Btw I'm allready running 30P's.
I'ts standard with 377 Scorpions.
#42
Silent Thunder Remove / Tips
Fastech 353 with pair of 500's. I have a huge hole in the bottom of the ST box. Not sure if to patch this hole or switch to tips.
My concern is the labor to remove the raw tips and replace them with Corsa CC .. wow -- that is a lot of work in 100 degree weather. I was hoping for more of a slip-over chrome tip with a flapper valve that can be installed in minutes? Anyone heard of this?
What happens if I run this with the hole? Funds are a little short to be buying $1000 in Corsa CC diverters.
So if I get all these posts right ... I can pull off the ST box with a few bolts and so tugging. --- then there are unpolished stainless tips sticking out about 4" or so. -- I can buy some rubber 4" flappers and clamp them on and be done with it? Is that correct? Or maybe someone has something sexier that clamps on fast.
I will change to Corsa CC when I pull the engines for rebuilding as I have 400+ hours now on HP500's with zero problems. I just don't want the hassle now.
#44
can someone point me in the direction of rubber flappers to buy to keep a stock look?
also how long does this mod take...we have a 03 292
does this mod increase the chances of water ingestion?
#45
I used these when I pulled mine off...
http://us.binnacle.com/p2320/EXHAUST...duct_info.html
Price is right, and you can't even see the tips when it's in the water. My stock tips also had internal flappers, so between the two, I don't think you will have any problems with water ingestion.
Mine took about an hour from start to finish, and one of the blind nuts came loose back in the corner of the swim platform. I had to lay on my side with a long pair of vice grips to get the bolt out, then seal the hole up. Once you get the bolts out, it takes a little encouragement to break it free. And it is HEAVY. A 2 person job for sure.
#46
#47
Before I got my current 353 I had a 312 that didn't have the silent thunder box on and it was pretty loud, but I just dealt with it.
Now the 353 has the normal setup and I like it better (looks better also), it has captains call so I can have it either way I want when I want.
#48
Can always slap it back on in an hour or so if you don't like it!
#49
thanks for the info guys...i think this is a nice little winter project along with a few others...
#50
I have an 02 292. Mine is coming off this winter or early spring. Just putting the flappers on. Boat sits low enough in the water probably won't see. Plus lost one of the bolts coming home from my season ending trip.
