GPS install (in-dash) for FasTech - Who has one?
I've got the Gaffrig speedo on the standard late-model (2003) FastTech dash. Since it is not working and I also would like GPS or SPG\chartplotter, I'd like to hear from those who have installed an in-dash GPS. I really don't want to use a bracket mount GPS which stands near vetrical on my dash.
Questions: What brand\size did you install, besides removing the speedo did you have to move any other gauges to fit, did you use an external antenna and where did you place it?
Pics would be great, too. Thanks.
-Rob
-Rob
Re: GPS install (in-dash) for FasTech - Who has one?
antenna attached w/two sided tape to flat of deck above cabin door next to the rise of "dash" There are spaces you can get the wire through to the unit. You can just see it upper left of this pic
I relocated fuel and volts and got the biggest plotter I could in. You can see it was tight in a number of ways. Using a holesaw for the guage relocate was easy next to cutting out that aluminum panel the shape for that plotter, in the boat!
You can one of the mounting studs fell right over the dash hinge arm mount. That's what that drilled hole is
I took a razor blade and had to cut out a few mm of the "H" crossbar to keep the FASTECH dash logo intact.
Charter Member #415
On your 292 it's going to be tough. Only spot is between the tachs where the speedo is now.You will need to measure the space there and search for a unit that is small enough,but that may be tough. Formula doesn't offer GPS on the 292 because of space limitations. They do offer Smartcraft System view 5000( about the size of a small GPS) but they use a different panel that eliminates some of the gauges incorporated into Smartcraft. You would need to buy or make a new panel and lose(or relocate) a gauge or 2 or 3. It may be doable,just won't be easy,353 and 382 have more room.
Where To
I mounted my plotter between the tachs as Robert said. It does not interfere with the visibility of anything.
Dave
Dave
Dave
Dave
the sunset from Sixtown Point anchored for the night.
uhhh...that's in Lake Ontario for those of you tethered to the river.
at least that's what my plotter told me.
Thanks, guys. Since I will spend alot of time in the Sacramento Delta, it would be nice to have the chartplotter - Hundreds of miles of waterways, easy to get lost or (even worse) run out of gas trying to find some backwater fuel dock with nothing but charts and the yellow pages.
If I can't find an in-dash unit that will mount flush I may go with a handheld. Thanks again to all for posting the pics and advice.
