Wet Floor in 357
Wet Floor in 357
I have discovered a small hole in the corner where the front board, the side and floor come together. When I lower the trailor jack so the front of the boat allows the bilge water to run to the front, the water will leak out this small hole.
Any ideas onthe best way to fix this. Has anyone ever removed the floor? Should I get it dry and just glass over the hole.
Charter Member #232
Can you post larger versions of the pictures?
Can you poke anything into the floor to see if the core is wet?
Jon
Jon
Put your best foot forward!
is this where the step is to go in the cabin or if it is toward the v berth? Either way, I think it is just a small grinding and very light fiberglass job almost anybody could do... But I'm not so sure looking at the pictures...
Unless it is all wet underneath these parts...
