Internal Flapper
Anyone know where I can get internal flappers for the older birds 87-91 with silent thunder boxes. Mine are burned out and I was going to run with the box off. Where can I get flappers for these? Are they special?
NO WAKE ENFORCER
if your going to run with the box off then get tips with flaps built in
http://www.cpperformance.com/product...haust-tips.htm
what he said, or you will have water where you don`t want it
I removed my ST box completely, and installed tips. The boat sounds great, without being too loud. The ride improved somewhat, due to taking a lot of weight off of the transom when on plane. The box weighed 95lbs dry
h2oboy, your exhaust is below the platform, formula18 has the Silent Thunder platform. Once he removes the platform it will be really loud compaired to yours.
I realize that - a friend of mine has a 29 Outlaw with the same power as mine. He has similar tips, with a tubular platform. His is definately louder, but I removed mine mainly to help improve the ride (new K-Planes are just not in the budget at this time)
I'm pulling my box off of an 02 / 292 but I'm going with the clamp on flappers. Not sure I am going to leave the box off so I don't want anything that permanent
