382 trailer in the Northeast?
Diamond Member #001
I need to move my 382 around a couple of times this winter to get all my projects done. Total mileage will probably be less than 200. Anyone have a trailer I can lease or rent? It will be indoors whenever it's not moving. Get your trailer out of the elements, and make a few bucks at the same time!
I might consider buying a decent used trailer for the right deal.
Forum Regulator
Chuck,
crb76 aka Clark Beecher has an aluminum Nextrail that was under his 37' Active Thunder. Its only got a couple thousand miles on it. Its an adjustable bunk trailer, which would not be hard to tune for your hull.
Its in TX. $3500 takes it. Shoot him a PM. I'll get you his number if PM does not get you in touch.
Chuck,
I have an 02 triple axle MTi that was made for a 353 that you would be more than welcome to use. I can even drop it off up at the marina if you want. I'm sure it could be adjusted for your 382. And the best part, FREE. Keeps it out of the weather and thats worth it. Let me know.
21 and 42 footers
BTW: the 353 and 382 have the same size steps.....I sold a 382 trailer to an OSO member who was buying a 353. We Checked with Formula and the step height was the same....obviously the weight and center of gravity are off but it could easily work.
Diamond Member #001
Treads - Hung the boat over the trailer while it was still on the forklift - Looks like everything's going to work out real well.
Thanks Again!!!
Thanks Again!!!
