added some bigger arrestors 6.2 gained 2mph >
Old 06-04-2015, 02:21 PM
SB
Received 3,233 Likes on 1,457 Posts
Nothing for this motor.
I was making a generic statement as I have designed and sell many 'niche' performance products.
That's all.
General public thinks if you have one part, you'll make a ton of many. That's what I thought at first but real life says nothing further from the truth.
That's why many 1 part or say even a dozen part companies , don't last long.
Cruel world - lol.
Some day my pea brain will discover something most households need. Now there's the chance for much better $$$$.
Oh well, back to getting greasy I go.
SB is offline
Old 06-05-2015, 08:07 AM
I should have said it could be beer money instead of cash. Small market with no repeat business.
Captain YARRR is offline
Old 06-05-2015, 10:41 AM
phughes69's Avatar
Coops, where on Fleabay do you see the flame arrestor for $40?
phughes69 is offline
Old 06-05-2015, 04:53 PM
http://m.ebay.com/itm/181753565651
This was the seller I bought mine from.
COOPS is offline
Old 06-06-2015, 08:03 PM
[ATTACH=CONFIG]541880[/ATTACH]
[ATTACH=CONFIG]541881[/ATTACH]
Here is how I mounted them
Out again today and I am more a solid 3mph better gps.
Remove the factory studs that hold down the throttle body.
Separate the upper and lower studs.
I tacted a 1/4 threaded rod to a 6mm union.
Make a spacer from 4 inch pvc to clear the linkage.
I made up some metal brackets that hold the pcv hose.
Put it all together.....done.
Attached Thumbnails added some bigger arrestors 6.2 gained 2mph-20150606_161931.jpg   added some bigger arrestors 6.2 gained 2mph-20150606_161925.jpg
COOPS is offline
Old 06-07-2015, 09:18 AM
Thanks for the pics COOP.
Are the three holes in the lid of the flame arrestor spaced out slightly more than the stock unit? It looks like the threaded rod is lightly splayed out.
I'm surprised that a change like this can make that much difference. But thinking about it, I believe Mercury uses the same size flame arrestor on the 5.0, 5.7 and 6.2 liter engines. Like you said, 377 ci engine turning 5000+ rpm needs a lot to breath. Nice job!
4mulafastech is offline
Old 06-07-2015, 09:45 AM
SB
What's the neck size of the throttle body ?
Seeing a 4" pvc fits on it, wondering if the old Carter AFS carburetor neck size of 4 7/32" is the same or near the same ? Might open door for better air cleaner spacers or etc ?
SB is offline
