Tried Q5 Hydromotives on 382 >
Old 09-09-2003, 05:02 AM
Member #9
hp500efi's Avatar
Robert, get well soon, the board needs you
Member of the Liquid Jungle
hp500efi is offline
Old 09-09-2003, 08:30 AM
Charter Member #415
Robert is basically OK,just some stress.Happens a lot,he gets burned out and has to regroup. He is going to doctor Wed AM,thanks for your thoughts. Karen
Magicfloat is offline
Old 09-09-2003, 09:10 AM
MrMagloo's Avatar
Troutly,
I hate to butt in again, but I humbly suggest that you consider testing w/o the spacers before you settle in on the props. As long are you are not running into cavitation problems - which I think you already said you are not, sorting this out should be the first step.
That alone, I think you will find a 100-200 rpm increase and that extra mph to two.
The worse scenario would be is settling in with the props, having them labbed, then realizing you don't need the spacers, and having to bump the props again. It's just a waste of time and money.
At the very least, do the spacer testing before the labbing.
John B., does your 382 have the spacers too?
Good luck.
MrMagloo is offline
Old 09-09-2003, 10:37 AM
Just what is involved with removing the spacers? I have never seen one. Is it simply a matter of unbolting, removing the spacer and reassembly? Or do you need to change internal parts too?
I too would think that if it is an easy change that you would first try the 5 blades with the spacers removed. The 5 blades may be fine at the higher x, specially if the original props were too high a pitch.
Padraig is offline
Old 09-09-2003, 12:46 PM
John B's Avatar
Troutly,
Once you try the 5 blades you will want them! They are the ticket for heavy boats. You can also run a higher x dimension, with less slip, and thus more speed!
Our x dimensions' could be the same. Mine has Stellings boxes which are 14 inch set backs, while your ITS's are 9 inches. Your's is borderline's with 4 blades, therefore, I think, Formula added the spacers. If your drives were down another 2 inches you probably would have way less slip, and wouldn't be able to pull the 30" B1's past 4700.
MrMagloo, Mine has no spacers.
Padraig, When you add a spacer you need a longer coupling for the vertical shaft, which you swap for a stock one if you pull it out. You also need longer or shorter studs etc. depending on which way you are going.
John B is offline
Old 09-09-2003, 08:41 PM
groove's Avatar
formulafastech,
Thanks for asking that question. I am a little confused myself. I think it might have something to due with the amount of slip. if 29's slipped bad, they may have acted like 26's?
groove is offline
Old 09-09-2003, 09:09 PM
John B's Avatar
Think of these props like a torque converter in a car, the bigger the diameter and the more fins the less slip.
Very simple right!
John B is offline
Old 09-12-2003, 04:58 AM
Member #9
hp500efi's Avatar
Originally posted by Troutly
Look what the cat dragged in.....can't wait to try them
Sweet
hp500efi is offline
Old 09-12-2003, 10:20 AM
turbosonic1's Avatar
Default Troutly Nice!
Please let me know how they work I'm anxious to hear! I will get a set right away based upon your results!
Do you need any Leak proof trim pump caps? Fancy ones?
Call me 949-589-9360 x 16 Lu...
turbosonic1 is offline
t500hps
Prop Talk
3
07-24-2008 06:47 PM
t500hps
07-24-2008 02:29 PM
baja36ft
Scarab
0
09-07-2007 09:20 AM
PARADOX
Prop Talk
4
08-16-2007 08:57 AM
Rebel_Heart
6
09-04-2006 11:02 PM
Quick Reply: Tried Q5 Hydromotives on 382
