Old 11-28-2004, 04:08 PM
  #441
Formula Outlaw's Avatar
Default Re: Post pictures of your formula!!!
Closer than last weekend.
Attached Thumbnails Post pictures of your formula!!!-boattips-003-small-.jpg
Formula Outlaw is offline
Old 11-28-2004, 09:43 PM
  #442
CBlakeNS's Avatar
Looks nice, I read in the other post that the tips are just double sided taped on cause you were anxious to see how it looked, but in the end do they have to be bolted or how are you going to secure them?
CBlakeNS is offline
Old 11-29-2004, 06:17 AM
  #443
There are three screw holds in the flange, so will predrill the transom and use stainless screws, also will seal the flange to the transom with a sealing compound, but NOT 5200.
As soon as my riser gaskets arrive, we'll put the hose on the risers and bolt the risers/spacers in place, then insert the tips through the transom into the end of the hose. Then secure everything. CAN'T WAIT.......
Old 11-29-2004, 06:20 AM
  #444
cuda's Avatar
Russ, use 4200 for sealant.
cuda is offline
Old 11-29-2004, 06:22 AM
  #445
Actually that's what I had in mind, plus I've got a brand new tube of it I haven't opened yet.
When I bolt in the "D" rings, I'm going to use that as well rather than screw around with those rubber gaskets, unless there is some reason I'm not supposed to do that.
Old 12-17-2004, 04:43 PM
  #446
turbosonic1's Avatar
382 can fly!
turbosonic1 is offline
Old 12-17-2004, 10:21 PM
  #447
CBlakeNS's Avatar
Nice man, I love that pic--you need to get some more!
CBlakeNS is offline
Old 12-17-2004, 10:34 PM
  #448
Just finished spraying my exhaust riser "spacers". Getting together with "Gusman" tomorrow to basically finish it. All that should be left will be wetsanding the transom and a couple small odds and ends. Even got two new batteries tonight. Will post pix soon as it's done.
Old 12-18-2004, 01:00 AM
  #449
CBlakeNS's Avatar
Nice man, definately looking forward to pictures as always!!
Good work and let us know when you finish.
CBlakeNS is offline
Old 12-19-2004, 10:07 PM
  #450
Been lurking from time to time and had to finnaly jump in. Saw the pic of the other 311 on Lake Powell. We are on the lake every other weekend or more all summer. Have not seen that boat but will be on the lookout. Here is mine. '90 311 Bravos. 450hp crate 502s. Dropped a valve in one Labor day. Back in the water this comming spring with roughly 600hp each. Cant wait.
Attached Thumbnails Post pictures of your formula!!!-f-311-small-.jpg   Post pictures of your formula!!!-cathedral-pic-small-.jpg
DustinM is offline
Quick Reply: Post pictures of your formula!!!
