docking light bulbs?
#41
Thanks!
I try to take a picture next time I stop by at the dock. The stock light is glued in a thick (3/8"?), U-shaped rubber 'cup' that's held in place on the tube by a hose clamp. Very simple and it works, I'd really like to pry the lamp out and reuse the rubber but it's very tight. I'll probably have to break the lamp first and pull it out in pieces with pliers.
A rubber spacer between the bulb and lamp might work, thanks for the idea. Probably heat resistant silicone instead of plain rubber, to avoid melting. The only (slight) problem is that it's flexible and every time you change the bulb, you'll have to make sure it's aligned properly - H3 bulb is held in place with a regular screw instead of twist-in bayonet mount. Back of the bulb isn't a problem, it's sealed tight, but one of the high voltage wires is partially exposed when the bulb is installed in the lamp and moisture is just about the last thing you want anywhere near it.
By the way, what do you mean by 'wireless'? The on/off switch being radio controlled? I'm using the stock docking light switch, wires and fuse to power the ballasts; nothing fancy, just lots more light when hit the dashboard switch.
#44
Update...
I ended up making an adapter, 30/20mm diameter, 3mm thick aluminum ring I screwed and epoxied to the lamp. I also drilled and tapped it, with 170/190° spacing to ensure that the plastic base HID bulb stays in place firmly. Tightening the screws will provide an airtight seal.
Next I'll have to figure out a way to protect the setup from anchor chain. I've thought about cutting a length 12" PVC drain pipe in half and screwing it to the hull, but that'll have to wait.
They're having a fireworks competition at a bay nearby tonight and I'll try to have this one lamp installed before that. I'll have to navigate back home in total darkness and if there are no coast guard boats around, I just might 'forget' to turn off the docking lights at some point...
#46
Update...
#49
How do the factory lights come out and how did the new fog lights mount in? What HID kit did you use and how did the bulbs mount in the new fog light housings? Did you have to run any new wiring? Can you show a link to the kind of fog lights you bought? any more pics of the install? Thx and sorry for all the questions.
#50
