Fuel Tank Diagram and Specs for SR357
I got the factory drawings a while back for the fuel tank on my 1987 SR357. I scanned it and will email file if it will help anyone--it's too large to post.
Poorsche
Poorsche
Re: Fuel Tank Diagram and Specs for SR357
That is a great resource.
I think my fuel sender in my tank is going bad. I looked at the sender (VDO) but couldn't determine the part number.
FYI--If you can replace the VDO gauge then you replace sende that would be a good thing. VDO gauges and senders are different that everyone else in that world and there is no way to interface except by changing sender and gauge.
I found that out after genset was installed over sender and needed to replace after it took a dump.
I'll email you diagram and part number when I get home tonite if it will help---
Poorsche
Poorsche
Poorsche
Poorsche
