How much deadrise? >
How much deadrise?
How much deadrise?
Old 07-06-2004, 04:42 PM
BAD-HABIT's Avatar
Default How much deadrise?
Trying to figure out how much deadrise my 1986 F3LS has...As a second question how does more/less deadrise effect speed and handling? I assume that the deadrise would be the same as an 86 242LS but Im not sure. I would like to find out for sure...
Randy
"Bad-Habit"
BAD-HABIT is offline
Old 07-06-2004, 04:55 PM
cuda's Avatar
Default Re: How much deadrise?
The 242 is a 24 degree deadrise. Less deadrise will usually give you a higher speed, but at a cost of pounding.
cuda is offline
Old 07-06-2004, 05:04 PM
cuda's Avatar
I could have sworn I saw the deadrise of the boats listed on the Formula site in the vintage area, but I just looked, and it wasn't there. The boat is 21'6" and weighs 3500 pounds.
cuda is offline
Old 07-06-2004, 05:53 PM
BAD-HABIT's Avatar
How would a 24* deadrise compare with Baja's,Checkmates,Fountians,Donzi's etc....
BH
Old 07-06-2004, 07:16 PM
cuda's Avatar
BH
It depends on which model. Most true offshore boats have a 24 degree deadrise. I think Sutphen has a 26 if I'm not mistaken.
cuda is offline
Old 07-06-2004, 10:55 PM
dockrocker's Avatar
Some Sonics are 25 degrees, but *most* V-hulls are 24 degrees, give or take a degree (some beak boat models are 23, I beleive)
dockrocker is offline
Old 07-06-2004, 11:45 PM
cuda's Avatar
I think the 26 Donzi Zx is 23 degrees. I think this measurement may be a little deceiving. It is measure at the transom, but will gradually flatten out along the bottom. I don't think it is the end all in figuring how a boat will ride, but it may be the only hard figure to look at that can be compared from boat to boat.
cuda is offline
Old 07-09-2004, 11:42 AM
BAD-HABIT's Avatar
Formula just got back with me and stated my F3LS has a 22* deadrise.....
BH
Old 07-09-2004, 11:45 AM
Thumper292's Avatar
HeyBH, Have you been on Caesar Creek near Waynesville, Ohio? I thought I had seen that boat out there. I have a 292 and usually spot other Formulas when I'm out.
Thumper292 is offline
Old 07-09-2004, 04:20 PM
NO WAKE ENFORCER
88formula223's Avatar
I goto caeser's almost every sunday have a grey 223 LS
you ever take that 292 outthere???? Love to catch a ride on that sometime!!!!!!!!
PJ
88formula223 is offline
Quick Reply: How much deadrise?
