Things I learned from the 336 schematics >
Old 03-15-2005, 09:14 AM
CObarry's Avatar
Default Things I learned from the 336 schematics
Some of this is probably common knowledge for most of you, but coming from a single engine ski boat I learned some things that aren't obvious that I think are worth sharing.
  • If you have shore power, the battery charger is tied directly to both batteries, bypassing the battery switch completely.
  • The output of both alternators is tied together before the battery switch. This explains why there's only one voltmeter on the dash.
  • Because both outputs are tied together, you could have one alternator dead and not know it. The only way to check is to run each engine by itself and check for proper voltage.
  • The setting of the battery switch also determines which (or both) of the batteries will be charged by the alternator(s).
CObarry is offline
Old 03-15-2005, 12:23 PM
21 and 42 footers
t500hps's Avatar
Default Re: Things I learned from the 336 schematics
Always had twin engine express cruisers before, but glad you posted this. Confirms some of the things I may need to know one day.
t500hps is offline
slik22
3
04-24-2008 03:08 PM
Lee
General Racing Discussion
11
07-06-2005 07:04 PM
HyperBaja
05-05-2003 08:57 PM
FunHome
05-28-2002 11:49 PM
Quick Reply: Things I learned from the 336 schematics
