Fuel in bilge!!!
Originally Posted by 10x
Joe
That tube should be on both sides of the center stringer, and it ends right at the bulkhead just behind your rear seat.
NOPE.....That area is sealed off!
There is a teflon/plastic sheet that has the diamond texture to it when the gel coat is sprayed in the repair area it is overlayed with the sheet and removed when dry We have done it a few times at the shp and it looks good when done.
I have same issue on 2001 Fountain 38 T.E. Main Fuel Tank fill hose is cracked and leaking and needs to be replace from deck fill to tank entry. I am having trouble finding the tank entry. I have located the vent line which is located in the head under the console on the port side near the the bow end of the tank. I just can't see where the fuel fill inlet is to place access panel to service and replace so far. Does anyone have any ideas? Can you send me Art Lilly contact information as he seems to know how to handle this one. thanks
SLINGSHOT
02-10-2005 07:32 AM
