35 2000 twin step
1 Post
35 2000 twin step
Does anyone know in the ist year model change with the 35 twin step, did they do any experimenting with the x dimensions or locations of steps or any changes in 01 to correct 00 problems if any. I know in 95 1st year of single step they moved step around untill they found sweet spot
thk Joe
thk Joe
Re: 35 2000 twin step
2000 was the first year of the twin step and fountain had some problems with the X dimension and the ability for the boat to come out of the hole. In 2001 they fixed the X dimension and no problems. I own a 2001 35' Fountain and do not have any problem with the new set up. I would not buy a 2000 if I were looking. Not much difference in price to set up 1 year.
Hey Mike,
Do you happen to have any info on a 2000 35 Classic (single step) with the HP500's? Just curious on top end and how they got up on plane...thanks.
G-
G-
Originally Posted by gferdon
Hey Mike,
G-
G-
1 Post
Thanks guy's I would have thought that the 00 would of been a higher X dimension because I read somewhere that some of the oo had a problem coming on plane and some boats where sent back and fountain installed a spacer to lower the drive, I also thought that 01 went to merc., props because of merc'c involvment with fountain. I am know worried is buying a 00 because you can always lower your drives with spacers but to raise alot more trouble and expense.So from what I am reading the merc prop likes a higher x than a hydro. If this is the case an oo would be okay with a hydro with the lower x dimensuion?
My boat is a 35 01 but it ran 84 with 30 bravo's and 500mpi's I wonder how close my 01 was to the last 00 mold . Can you tell by the serial # FGQ35554D001.
