Looked at a 92 35 need advice
Re: Looked at a 92 35 need advice
Originally Posted by 27 redline fvr
Yes it need to be painted it must have sat on a lift in the sun for quite some time thats alot of money for a 17year old boat
Wet sanded it with 320, 600, then 1000 and buffed it out about 3 times with 3M heavy duty compound. Looks brand new. I never tought the boat would shine again... I was wrong.
It took alot of hard work, but it really paid off.. all 38 feet of it!!!!
Originally Posted by BlondFountain
Our was really, REALLY Chalky... you could write your name in it.
Originally Posted by barron
After that sanding don't you need to clear coat the boat?
Had to take the baby boat out with the canvas up and the heat on......
Not in NY... I don't know about Florida. We are lucky if we even see the sun. This past weekends high was 51 degrees.
In 92 they were still useing The Good single stage Imron the stuff will chaulk up in time but will buff back perfect Its like Iron ! the hull again also should buff rite back..
they are small stress cracks in the gel on the gunwales right at the front corners of the engine hatches is this normal, is there any other differences in the older 35's verses say a 1995 other than the steps
my 91 42 has the same cracks, so did my 93 29........i wouldn't let that stop you...Tom
