Air activated Silent Choice
Ginger or Mary Ann?
My previous boat had a leak at the small relief valve below the pump. Took it apart and cleaned, then never another problem. Other than that, just start checking the fittings and the cyls. with soap and water holding the pump on.
Registered User
Registered User
Yeah I took the little pop-off valve out and replaced it with a small pipe plug to see if that was causing it, no good. Are the Cyls hard to rebuild, or should I switch to electric
Ginger or Mary Ann?
Last boat had the air system. Current one has the electric. Love the electric.
