P5Xs lift 35' to New Speeds
I just returned from an early morning run. What a great experience! Last week, I ran the stock 32 Bravos to 95 at 5600. Today, ran the stock 31 P5Xs to 98 at 5600. I did have some chime walk on one pass. Don't know if I had it trimmed out too much, or if I hit a little rough water?
I would like to see the engines turning 5800. Is it worth turning the engines to 5800, where the dyno sheet says my top hp should be? Anyone had any luck labbing a P5X?
Triple digits are right there....................
Just checked the dyno sheet. There is 11 hp difference per engine from 5600 to 5800. I spoke with Tom at Hydromotive and he calculated my slip down from 16% with the Bravos to just over 10% with the P5Xs.
There is a recreational lab they do for $385/prop to true the prop and get additional rpm. Do you think that I would gain any speed?
Charter Member # 545
Congrats, nice job.
![Cool](/forums/images/smilies/cool.gif)
Thanks for the feedback. Tom and I talked about a recreational labbing of the props. He said that would just true the props rather than a professional finish which takes the prop to very thin edges. If the props were out of balance this would help. Of course, can't guarantee any increase in speed. Don't want the props to go past 5800 because the rpms drop to what the rpms are at 5600. But after speaking with Tom, it seems that the labbing usually only nets 100-150 rpms.
