Replacing fuel pumps on T420's, any suggestions ?
Needing to replace both fuel pumps on original T420 blocks, mechanic told me the cam is really straining the ones from the factory. Can anyone suggest a brand and model.....to keep er' fed.....
10x
Go with the Edelbrocks. The street pump will be fine. Don't need any regulator with that one.
Fountain powerboats rule "The Preacher"
Chicago Powerboat Club Director
[email protected]
www.chicagopowerboat.com
[email protected]
thanks for advise 10X, I have an 89 10 meter, had problems with port engine eating the gears off my distributor. ( first time happening.. only 40 hours on rebuilds) pulled the engine and want to fix a lean popping problem... with both engines. do you ever make it to LOTO in the summer ?
[QUOTE=poiuy10;2442823 mechanic told me the cam is really straining the ones from the factory. Can anyone suggest a brand and model.....to keep er' fed.....[/QUOTE]
Cam is straining the fuel pumps??? I don't understand... I bet the fuel pump lobe is worn off the cam reducing fuel pressure. Seen it many times. I'd install a pair of electric pumps.
Good luck,
Kurt
Good luck,
Kurt
