Shift cable >
Shift cable
Shift cable
Old 10-12-2008, 07:49 PM
Registered User
35 White Lightning's Avatar
Default Shift cable
Has anyone ever had a shift cable pop out of the aluminum holder. I had the outdrives trimmed all the way up backing off of a shallow ramp, I went to put the starbord motor in neutral and it was stuck in reverse. I pulled the outdrive everything looks ok. I was just wondering if anyone had this happen to them attributing it to having the outdrive trimmed all the way up..
35 White Lightning is offline
Old 11-02-2008, 09:52 AM
carney's Avatar
I have seen where you my have to bend the tab down , I have seen them be really tight in the area in which they travel. causing them to stick in gear.
carney is offline
Old 11-07-2008, 07:38 PM
35 fountain's Avatar
I honestly hope you did not put that thing in gear with the drives in the trailer position
35 fountain is offline
team Tickfaw
6
11-09-2007 09:36 PM
rrentsch
Powerquest
13
11-06-2007 03:56 PM
DrFeelgood
Drives and Lower Units
5
11-05-2007 10:42 AM
atthelake27
5
07-23-2007 09:09 AM
obnoxus
0
05-15-2002 07:18 PM
Quick Reply: Shift cable
