Prop suggestions....
Keep in mind as set of bravo 30 pitch wheels done rite is the fastest prop for a fast boat. Not a really fast boat. As from my experience 6000 rpm. Is the roof for bravest, after that lowers puke,1:36 is also the strongest gear. Considering prop speed in your performance goal for handling purpose you may want to consider the upgrade.
10x
Not up on the bravo stuff, but why is the 1.36 gear set the strongest ones ?? You sayin use the 1.36 with a 30 prop ?? Just curious.
Fountain powerboats rule "The Preacher"
Chicago Powerboat Club Director
[email protected]
www.chicagopowerboat.com
[email protected]
![](http://i4.photobucket.com/albums/y137/purple66bu/motorsindaboat.jpg)
Had a similar set up on our last 35... 1 step, standoff boxes, 585 hp per side, 1.5 gears, max hp at 5600 rpm... no shorties, though..
29 Quad IVs 65MPH @4500rpm, 76@5000, Hit rev.lim.(5600) 85mph
29 P-5's 72 @4500, WOT@ 5200 87.4mph
31 5bl(CNC) 76@4500, WOT@ 5200 90mph
Throttle up
Hope this helps, we ended up with the Throttle Up 5 blades, but a labbed pair of Hydro P-5's was very close in overall performance.
Carder
Throttle up
Carder
![Drink](/forums/images/smilies/drink.gif)
Mikey....I have standard Bravo 30's....let me know if you need to try them. I turn them around 5,000 with my HP500's and will most likely send them out to Brett at BBlades this Fall to be labbed.
Thanks Mike! I'll be in touch when it comes to test time. Got the boat home after towing on icy roads this Saturday...yeah...don't ever ever ever do that. Spent 2-1/2 hours PARKED on I-80 cuz some jackhole rear-ended a state trooper. Boat is absolutely filthy...just covered in road grime...I've got some work to do.
![EEK!](/forums/images/smilies/eek.gif)
Me too. ![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
Ugh.
That is an absolute nightmare scenarios.
